Danfoss TP5000 Si Range Programmable Room Thermostat
4 Oct 2011
Durham
I was hoping someone can tell me how to change the thermostat so we can programme 6 events per day? It is currently set up for 4 but says in the manual that the installer set this option - 2, 4 & 6 events are available according to the instructions but it doesn't say how to change what the installer has pre-set.
e.g.
Event Time Temp
1 07:15 19.5
2 09:15 21
3 18:15 21.5
4 23:59 15
5 not currently available
6 not currently available
a) Press and hold V and PROG for 3 seconds to enter User Advanced Programming.
b) Press and hold V, Λ and PROG for 5 seconds to enter Installer Advanced Programming.
c) Use + and - keys to scroll backwards and forwards between options then V and Λ keys to change the option settings. The flashing digit on the right hand of the display indicates the number of the selected option. The large characters display the option value selected.
Go to option 40
Increase 4 to 6 using the Λ button.
This should give you 6 time programmes a day. Press and hold PROG to finish.
HTH.
