- Joined
- 23 Aug 2007
- Messages
- 88
- Reaction score
- 0
- Country
I'm planning a decking patio. 6.5m wide (decking running across the width), 2 to 2.6m long (joists running this way). The joist spacing will be 400mm so there will be 14 joists wide.
I'd considered using risers/pedestals - the really low ones - as I have a level access patio door (new build) so don't have lots of depth. Using 100mm timbers I was looking at having the pedestals 600/700mm apart which would result in a matrix of nearly 70 risers - which seems bonkers! I don't want to use timber posts as the ground is quite damp.
I wondered whether it might be easier to make 4-5 long concrete cast beams in contact with the well compacted type 1 MOT under the current patio slabs. I could dig small holes along the length to act as piers/footings, lay a length or two of rebar in there and cast in one go. Then the joists could run across those.
My question is: does this seem mad?!
Thanks in advance!
Thanks in advance!
