Hi all,
Got new t&g chipboard floorboards (18mm) flooring put down in a new loft floor. I don’t believe the builders properly glued everything as they should so it was making squeaks / popping noises a lot. After couple of builder visits and additional screws, my own attempts at adding many more screws across all joists and after finding supporting noggins, it’s a lot better.
However, there is just this one main deep rubbing / groaning / grating noise (not the usual squeak/popping noise) coming from near the short edge of one of the floorboards which is making me mad. The area in question is in middle of the room where short edge of two floorboards meet. There are overlapping joists exactly under this area sitting on an internal wall. One of these joists sit exactly under the short edge joint (supporting each board with roughly half its width). The other overlapping joist is on the inside side of the problem side next to the short edge.
I have tried adding lots of additional screws on both joists through floorboards, even added pu expanding glue in some screw holes in this area and screwed it back (it was suggested this can help with and minor gaps between floorboards and joists). But no improvement to the noise at all. The noise is deep rubbing, groaning, grating which happen when I step near or on the short edge of the board and then get sort of a reverse noise when I step back (in see saw king motion).
My last theory is sound maybe coming from the t&g joint itself on short edge rubbing deep inside. Talcum powder hasn’t helped as joint seems too tight for anything to go in. Any help / suggestions would be greatly appreciated.
Desperate for some help as I am running out of time before carpet gets put on in couple of days time.
