DHW for dummies - how should I heat water in my rental flat?
23 Feb 2011
Have just moved into new build flat and struggling to understand modern day heating system - am used to DHW on demand via combi boiler so would be very grateful of any help!
Boiler is Ideal icos HE15, HW tank is Heatrae Sadia Megaflo CL125HE.
What should I use to heat up water - the immersion heater directly or combi boiler?
With boiler on timer, water heats up but boiler seems to run intermittently with ignition light flashing while it's not running.
With immersion switch on the Megaflo tank on water heats up (quickly) and water is eventually scalding hot - have also seen slight drip from T&P relief valve on one occasion.
What's the most efficient and cheapest way to heat the water please folks?
Gas is more economical than electric. I don't think your boiler is a combi. It is likely to be either a heat only boiler or a system boiler. The combined temp and pressure relief valve dripping usually indicates that the expansion vessel requires repressurizing. Some cylinder have an integral air bubble instead of an expansion vessel. This needs to be recharged usually annually or bi annually.
..With immersion switch on the Megaflo tank on water heats up (quickly) and water is eventually scalding hot
Sounds like the immersion thermostat is faulty, or wrongly set. More modern ones have an overheat cut-out.
