Can any one help me with this dishwasher??
The machine will start a cycle, pumps out and just as its going to fill the the 'start' light and the programme light will go off and on together at the same time, it sounds like it is pumping and filling as the power is switch on and off. it does this for about 6 on/off pulses before it will stop and repeat it again. each pulse of the power/ light flash is about 1 second in time.
it can repeat this for about 3 or 4 times and then eventuality start. i don't think this is a normal fault code because i tuned off the water supply to see what it would do and it did give a code of quickly flashing 'start' light with a constant programme light. i can't find anyone else who has had this fault in the forum.
the wash arms are free and clear, filters clean, no water in the sump under the machine, no kinked hoses.
can anyone point me in the right direction of what this fault is???
the manual is a whirlpool adp/agp if that helps
