At present I have a washing machine plugged on a single gang socket behind it, under the work top. That space is on the right of the sink. For some reason the fused 13A switch for the socket is under the left side of the sink compartment.
I am fitting a slim standalone dishwasher unit under the left side of the sink (the flat part of the sink).
| DW | SINK | WM |
There are two issues, firstly I need to move the fused spur of the WM so that I can have access to it, or it will be behind the DW.
Secondly I need another socket for the DW and separate 13A spur for protection. I could pull the DW cable behind the cupboard void and connect to another available socket. But i) it will be behind the fridge ii) no spur.
I was thinking of a wall mounted configuration as it can all be laid on the wall under the worktop to save from chasing wires into the wall. The circuit is the ring of the ground floor sockets, protected by a 32A MCB and CB has dual RCDs.
1. What is the best/easiest configuration to have both connected?
2. Any chance the simultaneous load of the DW/WM would cause any problems?
| DW | SINK | WM |
