Hi All
AEG Lavamat F65011V1 DISHWASHER fails to wash. Any advice before I junk the machine ?
I have had the above AEG dishwasher for nearly 6 years and, apart from the lower basket wheels falling off on a regular basis, all has been fine until about 6 weeks ago, when it just stopped washing for no apparent reason.
I called an engineer out to fix/diagnose the problem and he said that the main [circulating] pump had failed and it would cost £200 to replace it.
This did not seem to be cost effective for a machine of this age and use so I sourced a new pump and capacitor online and replaced both myself [genuine parts]
Once this had been done, water, waste and power was restored and the machine was tested. Much to my surprise, there was no change in the machine.
I then tested the ‘old’ pump for continuity on the windings, and tested the ‘old’ capacitor with an analogue meter [not conclusive I know, but indicative] and both were found to be perfectly serviceable.
The exact cause of the circulating pump failing to run is still a mystery to me.
I have reset the dishwasher several times and it has spent several weeks disconnected from the power supply as well. The dishwasher:
1 Switches on and all relevant lights illuminate, as normal.
2 Program function switches respond as normal
3 The washer fills with water, as normal
4 Then, regardless of the program selected, the dishwasher remains silent [apart from hearing the detergent draw flipping open] as the circulating pump does not run, this is NOT normal
5 When the evacuation pump is called into action, it functions as normal. Dependant on the program selected, the machine might fill and empty again but at no time does the circulating pump run.
6. During the cycle [what ever program is selected], the countdown timer falls as expected.
In short, everything happens as would normally be expected [timer, fill, empty, heat, dry, lights, buttons, detergent] EXCEPT the arms do not move as the circulating pump does not run.
I contacted AEG regarding the problem. Basically, they said that as I am not able to diagnose the problem myself, I should call another engineer, other wise they could not help !!
Most disappointed with AEG when I consider the SUPERB customer service I have just had from Bosch for a 10 year old oven.
MHFLS
MHFLS
