Distemper under flaking ceiling paint?
1 Dec 2008
Bristol
In my new flat I had noticed flaking paint on the ceiling.
The general finish of the outer paint surface was slightly rippled
The ceiling paint comes away really easily in large pieces with a scraper (very theraputic)
The rippling seems to be the powdery layer underneath the outer paint layer. I wonder if it became rippled when the paint was applied and the powdery surface redistributed itself while it was wet?
The underneath layer is grey-white. It scrapes relatively easily into powder, revealing the plaster surface underneath seems to be lovely and smooth
Likely to be distemper?
What would PVA look like?
Thanks for any help
Very likely to be distemper :idea: PVA is best left on the shelves @ DIY sheds :shock: Look @ it there if you must .
Early victorian
Distemper it is then
Unless the ceilings have been replastered.
Scrape off a bit and test it. It will dissolve in hot water but not in cold. If you wet it you will get an unpleasant smell of boiled up dead horse's hooves.
