Hello,
I'm looking for advice please on damp proofing my new (build from scratch) shed base.
The shed is a lean-to building, attached to the side of the side.
3x2 pressure treated frame for base and walls.
Below the timber floor frame was an existing base from a path covering half the area so in my wisdom I decided to try to use concrete slabs (concreted in place) on the other half and then lay the frame on top - following a brick line in the house to keep it level longways. I have now filled the gaps beneath the frame with concrete (not shown in pic) - it now feels very solid and the bounce has gone. I also didn't want to concrete this other half as it was banked up and there are now pipes just under the height I've dug to.
I did unfortunately forget about damp proofing and I'd rather not life the timber frame if possible as concreted in and bolted to the wall.
Would it be suitable to use a DPM (I've already bought a load from Screwfix) on top of the frame? (as well as wrapping the walls in it).
Pics attached.
I am a complete novice at this! (as you'll probably tell from the pics).
Thanks, Ben
Pics attached.
Thanks, Ben
