Long story short, I drained the cold water storage tank at the weekend; the hot water cylinder ended up empty too; and by the time I came to refill, I noticed that the pressure in the heating circuit had dropped to near zero.
Advice needed: could anything cause this other than a broken coil?
Some more detail: The boiler's in the loft, along with an expansion vessel for the heating circuit with a pressure gauge. There's a filling loop which is teed off the mains cold supply on its way up to the CWS tank. There's also an automatic air vent, and an overpressure valve which drains outside. The heating circuit is divided into three heating zones plus hot water by electric valves.
We moved into this house about 3 months ago. Soon after, I bled all the radiators. A lot of air came out, and I topped the circuit up to about 1 bar afterwards. Since then I've noticed maybe a couple of times that the pressure was getting a bit low again, but there aren't any visible leaks, so until this weekend I assumed it was just more air working its way out of the system.
Anyway, on Saturday I shut the supply off to the CWS tank to service the float valve. That turned out to be more of a job than expected and it wasn't until Sunday afternoon (by which time we'd used up all the water in the CWS tank) that I got to refill it - by which point, as I said, I noticed that the pressure had dropped to near zero - and I'm pretty sure that it was fine before I started.
I've not noticed any discolouration in the hot water, but what else could cause this other than a broken coil? I'm hoping it's not that, because (a) I could do without the expense, and (b) somebody has built the HWC in behind the bathroom wall so it's going to be a pita to change.
