dodgy js speedfit connections?
16 Jun 2006
London
I am not a proper plumber, but... On site this morning, I went to use the outdoor tap and noticed that one of the t junction speedfits had split because of the frost. I mentioned it to the customer and suggested that it would be OK for a day or so until the frost went. It was cold- so I went to the pub. I then discovered that the pipe had thawed and was peeing out water. I went to my local supplier and picked up a new JS t junction connection. I fitted it (on copper pipe). It spat water out of one side. I flipped it over. It spat water out of the other side.
It was getting dark but I couldn't see any deformation in the copper pipe. I did, retrospectively sand both bits of copper pipe with 180 grit mesh paper.
Was it just a dodgy fitting or could it be the case that I nicked the o-ring? I have never has a faulty JS before.
Tnx in advance
I looked at it today. I seem to have managed to damaged the o-ring.
It must have been when I was trying to force in a copper pipe at an angle.
Mea culpa.
Yup, always wise to have some silicone grease to hand and use the lightest smear when using any push fit fitting, especially with copper. Just helps to ease the pipe past the o-ring with min effort.
Thanks, I didn't think of that. I normally use spit.
A little grease on any push fit allows the o-ring to be lubricated and makes the use and re-use of the fittings much easier and stops the o-ring from sticking. I carry in my box anyway, so dead easy to use.
