- Joined
- 27 Jan 2008
- Messages
- 27,705
- Reaction score
- 3,357
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I have installed a new door bell for my mother Response Electronics Ltd WIRELESS DOOR INTERCOM SYSTEM (CL6011B) which seems to work well, but the bell push is at the moment powered by two C cells. These can be replaced with a 12VDC power supply but the instructions says replace so it would seem I can't fit rechargeable cells to replace the primary cells now fitted.
C cells are big I know but it is working an intercom so may not last that long. Has anyone used one of these units if so how long do batteries last? Is it worth hard wiring?
Also when the button is pressed there is about a 4 second delay before bell rings is this normal or is there a fault? It buzzes at the door twice before hand set rings.
I have been told by the councils electrician that the door release can't be fitted to back door as not enough frame to mount it on and can't be fitted to front door as it opens outwards. At the moment not an issue but may be as my mother gets older. I can easy change key safe number so once she gives it out I can change it but door release would be easy option. And of course if anyone runs off with key it's a lock change job.
She is very pleased with it she says it saves her answering door to god salesmen/women it seems she gets loads far worse than double glassing salesmen. She is in a wheel chair and it's not easy answering the door.
