- Joined
- 24 Oct 2013
- Messages
- 3
- Reaction score
- 0
- Country
my front door (inward opening) has a weather seal at the bottom threshold in the form of a 'rubber' flexible strip mounted on a metal (I believe) carrier. The flexible strip butts up against the bottom outside face of the door when closed (i.e. it does not go UNDER) preventing drafts. (Similar in function to a Weatherstop garage door seal, but on the outside). As the door is in a porch, I am not worried about rain.
The flexible strip has warn away in the middle I want to replace it with the same, if possible. This would reduce the carpetary needed if using some other solution The strip carrier is about 4.5cm wide and the flexible strip itself about half that.
I cannot find this anywhere. Does anybody have any suggestions?
thanks
MD
thanks
MD
