Door with sidelights
22 Nov 2009
Oldham
My sister has an arrangement similar to that below but a bit wider, it's over 30 years old and ready for replacement but she would like something that doesn't bounce, shake, rattle and bang when she shuts the door.
Will a replacement be more solid than what she has now - I'm not sure whether it's the quality of the old door and frame, loose/insufficient fixings/dissolved foam and silicone etc which would all be resolved by a new, well installed good quality uPVC/composite unit or whether she should be considering aluminium or a reinforced frame (or something like bay poles that go in bay windows). She's pretty tight but will spend money when she has to!
I'm unimpressed by plastic doors.
A wooden door and frame typically lasts more than a hundred years. But unless it is protected by an open porch will need regular painting.
Composite doors are quite sturdy.
I fitted a Solidor with top and sidelights and that’s pretty solid. They join them with aluminium couplers so they stay strong.
I got it from Keyframe in Bolton.
We got an aluminium door from them. Very sturdy, insulated... RK Door Systems Ltd
That door and sidelights will be a bit springy when you shut the door.
I'm mean it's bendy plastic....and it will bend
