Double End Bath - Tap and Shower help
3 Nov 2006
Herefordshire
Hi All
First post!
I need some advice regarding some plumbing / fittings for a double end bath
Currently I have a tap at one end of the bath with a shower mixer coming off it. With the new double end bath, I want to put taps in the middle, but keep the shower at the end.
So I am guessing I need to split the water supply off to a shower control on the end of the bath..
Can anyone recommend suitable fittings or let me know if this is possible.
GC
photo below
http://img.photobucket.com/albums/v443/lordgaz/BathQuestion.jpg
lordgaz
Ok this is a que er one alright ,lol..lol..lol ;)
Im glad you supplied a picture .....
If I see it right you want to fit a new bath with taps in the middle an have the shower taps/water outlet recessed in the stud wall at the bath end, Yes ?
if you are having a replacement bath then no probs whatsoever ....
hope this helps ;)
speed fit/john guest or hep20 fittings all push fit make sure they all go properly home and fit isolation/service valves after you t off from existing supply to both shower and bath
