Double socket - FCU - Fire?
24 Sep 2008
Newcastle upon Tyne
I have an electric fire which has a plug on it, however I would like to be able to have it plugged into one of those switch type FCU's.
What I'm wondering is this.......
I have a double plug socket close to where the fire is going (I don't want to use this socket for the fire as it means the lead would have to trail over the wall). Can I simply run a FCU socket from the double socket?
Then is it just a matter of wiring the fire up to the FCU?
Is there different fused sockets for different appliances?
I have read the other topics on this but I really do need it explained in Laymans terms :(
Thanks in advance for any help/advice given.
Yes you can, as long as that socket isn't already a spur itself
Then is it just a matter of wiring the fire up to the FCU? <font=red> Yes it is, but make sure that the fuse is the switched fuse spur is the correct rating</font>
Is there different fused sockets for different appliances? <font=red> No. Standard 13 Amp ones such as the one you're considering are suitable for what you want to do</font>
Answers to your Q.s in body above.
Instead of doing what you are proposing, why don't you spur off with another double socket outlet (DSO) and keep the fire on the plug? It'd be easier to disconnect in the future (when summer comes or young kids are around etc)?
I have a double plug socket close to where the fire is going (I don't want to use this socket for the fire as it means the lead would have to trail over the wall). Can I simply run a FCU socket from the double socket? .
Yes you can
Yes it is
I assume you mean FCU's? If you do mean FCU's they all come with a 13amp fuse which can be changed for a smaller one only. What is the rating of the fire?[/quote]
