I've found a small leak on an isolator for our CH system (sealed system, no drain valve), so need to drain it ideally (I'll replace the fitting with a new compression isolator).
Any tips on how to do this with the least mess? Needed to get to this job at some point so now is as good a time as any. I'm expecting a lot of sludge as not done this before.
I've read the FAQ but it advised to use the drain valve my system doesn't have
