Drain and p trap?
2 Mar 2015
Devon
How many drain pipes can connect through a single p trap?
I was planning on a single drain pipe carrying the waste from three toilets and two showers, passing through a p trap before the inspection chamber. The trap suddenly looks pretty small, and likely to get blocked by toilet paper.....
Thanks!
From 3 toilets? Toilets need to be directly connected to the drain via 110mm/4" pipework.... Where does this trap feature? :eek:
If You're talking about a 110mm underground lowback P trap? That's really for use with gullies and exposed drains where they are connected to an underground drain further down creating a water seal to avoid drain smells, wouldn't be used in an vented soil stack that toilets would normally be connected to.
