I have a problem with smells. I do not have mains drainage, so use a private sewage treatment plant. Since occupying the house I have noticed an intermittent, unpleasant (sewage-y) smell in the downstairs cloakroom and the adjacent (platerboard wall) utility room. Checking the gully, I see that output from the sinks in both rooms and the WC come from the same drain outlet, so there is a common feedback route for smells from the sewer.
Doing a quick survey I could not see a drain vent pipe on that side of the house, so there is no outlet to the air for smells. However, I notice that there is a short length of drainpipe in the cupboard housing the pressurised hotwater cylinder. This is adjacent to the upstairs bathroom WC. The pipe is capped at a height of about 1 metre. There is a boxed-in section of about the same height beside the downstairs WC, and that might contain something similar.
Question: Have I got some sort of short, closed sewage stacks? Is this a common practice? Or should I really have a stack that opens through the roof in the usual way.
To see if the smell was feeding back up the sewage pipes, I temporarily blocked the outlet in the gulley (carefully NOT using the sinks or WC since!!!). The smell has gone away. So I think I know the source, but I don't know how it is feeding back into the rooms. All the same, would a stack solve the smell problem? Should there have been a stack all along?
Thanks for your comments.
