Hi, hopefully some of you can help me here.
I'm currently in the process of removing an old patio and retaining wall at our house. The old wall forms one edge of the patio, furthest from the house and has been wrecked by water damage. it's only 2-3ft high and holds the lawn back and I want to replace it with one made from railway sleepers.
Where I'm a bit stuck is how to drain it. Usual procedure is a french drain and I'm fine with how these work. Problem being I've nowhere to direct the water from it. I can't let it go out onto next door's property and the only nearby drain it can go into is at the back corner of the house, some 5m away.
What I hope to do is run the drain, in some kind of pipe from behind the sleeper wall, perhaps underneath it, underneath the new patio and into where the guttering goes into. If I don't do this I literally can't see where it can go and I don't want to flood the new patio or next door.
So my questions are, can I run a pipe under the patio? It will all be properly compacted with a whacker plate. if yes should the pipe be solid or perforated (where it goes under the patio).
Thanks for your help - Chris
DSC_2466
DSC_2467
DSC_2492
