We've got an open vented central heating system with a F&E tank in the loft and feed and return pipes to all the radiators. There's currently a couple of bottles of sludge remover in the system, which has been doing the rounds for about a month, and now needs to come out and have an inhibitor added instead. The questions I've got about this are:
1. Would you drain off from just one downstairs radiator, or is it better to do it from more than one at the same time?
2. Would it be better to stop the water coming in through the expansion tank, empty the system out altogether and then flush more water through, or would you just let the water keep going through until the water coming out is clear?
3. When it comes to adding the inhibitor, will it work its' way through the system just by putting it in the expansion tank, or is it better to put this in while the system is only half full of water?
Thanks in advance for any help - as always, much appreciated.
