Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
try cross bonding the pipes so when the seriously hoit water on the central heating side melts through that 3 amp fused cable and make the entire system go live.
there is an earth cable on the mains water pipe where the stopcock is,
if i cross bond all the pipes under the boiler together will this be sufficient?
what dia cable would i use?
and should i include the discharge pipe?
is there such a thing as 'too much earth bonding'?
Yes it will be sufficient. The minimum size you can use at present is 4mm. I always use 10mm as I am too tight to buy several different sizes of earth wire, and 10mm covers all possible applications that I need it for
