draining hot water
21 Jan 2004
I have a hot water cylinder that is fed from the mains water supply it goes through a special valve with a flexible hose coming off it could you tell me how to turn the hot water off please....thanks :(
What make is the cylinder?
Please expand "......could you tell me how to turn the hot water off please...." as I don't think you mean me to say "turn off the tap".
i need to turn the hot water off at the cylinder to move my bath, so i need to disconnect my taps
You will probably have to turn off the cold feed to the cylinder. It sounds like it is an unvented cylinder, and you should have a manual which will tell you all you need. If you haven't, contact the makers.
