Stop hot water on Greenstar 24i Combi
25 Oct 2008
Yorkshire
I need to put a stop end on the washing machine hot water feed pipe (tap leaking) as the new machine is cold feed only. On my old cylinder fed hot water I would turn off the hot water with a valve near the cylinder, however I have just had a Greenstar 24i Combi installed. If I power off the boiler and shut off the cold feed at the main stopcock will this shut off the hot water supply or is there a seperate stop valve in the boiler.
Thanks Mike
