I have a combi boiler and need to drain the system since a couple of radiator valves are leaking. If I've got this straight, all I need to do is to open a drain valve downstairs, open a bleed valve upstairs and hose the water out the window. Therefore I don't need to shut the water supply off as long as the valve that I use to fill the system when the pressure is a bit low is shut. Is this correct?
Also the valves that are leaking seem a bit old. The inlet and outlet are on the same side of the radiator. The inlet (which of course has the on/off) is the leaking bit. This fits into the outlet and the outlet then fits into the radiator. I've been to B & Q but their inlet valves all seem to fit directly into the radiator so the size of fitting on the inlets to go into my outlet is too big. Please, what can I do?
