- Joined
- 22 Aug 2011
- Messages
- 2
- Reaction score
- 0
- Country
I went into the attic and took a couple of photos of the small tank from where the dip down the over flow pipe originates.
What I suspect is that there is a small drip into the tank from the ball cock and was thinking of simply replacing siad ballcock assembly.
Do I need to take the whole assembly out and unscrew (?) it from the tank in its entiretity or do I replace the ballcock as there is a split pin which seems to suggest that I can simply replace this part.
If I undertake to remove the whole assembly I assume I turn off the mains first!
See 2x images for the tank as it looks.
Mr NotPlayedWithThePlumbingBefore
