Hi all, first post on here, prob more to follow because of the brand of boiler I have as I know they are prone to leak.....if only they made showers!!!!!!
So, it sprung a leak yesterday and it turned out to be a crack in the flow sensor (on the box it says 'bulex'). I released some pressure from the system, once turning the water supply off, and set about replacing the part (for the first time I might add). Afterwards I turned the blue knob to re-pressurize the system up to .8, as it was before. It then began to drip from the reduced pressure zone valve, which it has done in the past when refilling the system but overnight it's continued. Its only a slight drip, but a drip all the same.
Don't know if it's related or not but, when the job was initially finished, it was leaking also from a valve near the part I replaced, another component with a hand screw on top. After I tightened it, it stopped. I thought that was ok until I read in the manual this morning where it states on commissioning the boiler the valve should be left open??? So I have just opened it again a little and it now seems fine......touch wood.
So why is the RPZV still dripping, any ideas???
Thanks in advance,
Danny
Thanks in advance,
Danny
