Ducting route for cooker hood
17 Nov 2007
Southampton
I want to install one of these http://www.ikea.com/gb/en/catalog/products/S19872842
My brother can do the electrics (17th edition qualified etc) but I will drill the wall and route the ventilation pipe.
The pipe required is a 125mm pipe, which I can obtain easily from screwfix or toolstation. However, am I best off installing one length of flexible tubing up from the hood, round the 90 degree bend and out the wall (the 90 degree bend being where the pipe goes from heading up to heading out) or should I put a solid pipe through the wall and then a flexible pipe from the hood up to to solid pipe?
If the latter then is there a 125mm 90 degree bend that can be purchased and what is the best way to join this to the solid pipe through the wall?
I assume a worm drive clip to secure the flexible pipe to the hood and at the other end would be the correct solution?
CD.
You may be able to fit a reducer to take the flow out in 100mm pipe, the rigid pipe is a better option as it is more resiliant than the flexi.The pipework is designed too push fit with any flexi hose connected as you mentioned, avoid using cable ties [often supplied with fans] as they perish in the heat.
