I'm looking for a clear sealant to temporarily fill a gap varying from 1mm to 5mm between window and frame, just during the Winter. The sort of stuff they use for sticking CDs on the cover of magazines. The reason I can't use conventional draft proofing is the windows are those daft circular ones that open by rotating across a diameter. All I need to do during the Winter (ok I know its a bit late now!) is seal up the gap without it being too noticeable, then when Summer comes I want to be able to peel off the sealant so that the windows can open as per normal.
Any ideas? I have Googled in vain and very confused by the different types of sealant/filler on offer...high modulous/low modulous/acrylic/caulk etc etc.
Many thanks in anticipation.
