electric shower is running cold
15 Mar 2010
West Midlands
hi i got up this morning and the shower is running cold its a mx inspiration the light on the shower isnt coming on and the water is cold can anyone help....
Check main fuse/cb/rcd, is it ok? check shower isolation sw,is it ok? NO? then with all power off, check terminals for tightness at all connections. Still nothing? Shower fu£$&d.
don't listern to this t**t another one that can't diagnose a electric shower fault.
if the rcd etc was at fault then it wouldn't be running cold. :roll:
is the power light not coming on with either of the heat settings ?
power light doesn't light on only cold setting on this shower.
also check the pressure switch is being activated.
Sorry SECO, had a bad morning. I presumed the op had already checked the power setting.
