electric shower
23 Jan 2006
Manchester
i've got an electric shower but since yesterday no hot water comes out! what can the possible problems be?
as said above, if power ok check the following
the mains pressure is ok activating the microswitchs in the shower unit if pressure low microswitch will not give power to elements. if ok
check you have power to tco and is not an open circuit if ok check power to heating elements.
useally if a element gos it trips the shower main fuse.
if electric showers fail you can get replacements for as little as 50-60 pounds now! how would someone be able to check if there is power to the tcd and elements? with a voltmeter?
