Hi, any help gratefully received. Since my house RCB device tripped twice in the space of an hour (not related to wash mach fault, more to do with snow + outside lights) the above machine has failed to work.
The door locks, no other noises. The start/pause indicator flashes red and does not even, after considerable time, when pressed start the machine on any program. Have taken the back and top of the machine and can see no obvious faults, (no burn/damp/poor connection). No 'fault' codes are appearing on the display. Pump/Drive all turning by hand. Pressure switches click when blow/suck.
I guess this is a programmer fault, can it be re-set?
Thanks in anticipation
