Elkay Programmable light switch
1 Jul 2014
Hartlepool
Does anyone know how to rest these switches please (Elkay Customlight 790A). The display has gone blank as if the switch has no power?
Guys, i must apologise. After this hasn't worked for a few months I've literally just discovered the lamp that was in the light fitting must have been faulty. It didn't light up but when put in another fitting it worked for about 2 minutes then blew along with the fuse. I've put a new bulb in the light fitting connected to the Elkay switch and all is good now.
Thanks to you both for your very quick replays, it is really appreciated.
sounds like one i have, as you have found out, it uses the bulb to function, Mine has to be at least 25 watt, it will not work with Led or any low energy lamps, when the bulb last failed, the display went off
It takes it's neutral from the lamp itself, so if doesn't work if the lamp blows, of if it's low-powered.
