Emulsion removal
26 Feb 2007
Norwich
Just wondering what would be the best way to remove emulsion from a bedroom wall so I can gat back to plaster to fill holes and sand any lumps.Any ideas appreciated
Don't really need to just want to get the walls flat but a bit reluctant to get a plasterer in as it is not to bad and I can fill the holes myself. Just being a bit fussy really.
Also in one corner there is a small amount of mould due to lack of air circulation. Is there anything I can add to the paint to make this easier to remove should it return even though it should not now problems are sorted
Give the walls a really good rub down instead you will find it easier plus by the time you have scraped all the emulsion off the walls they will need loads of filling and rubbing again.
Re the mould...wash and scrub the wall with water and bleach 4:1 ratio leave overnight and rinse
Gonna be bloody hard work to get smooth by just rubbing down.
Have rubbed some down but it appears that before it was emulsioned last time all the wallpaper from before that has not been taken off completely. At least this is what I am guessing as most of the other rooms are wallpapered, looks like the back of the wallpaper has been left on parts.
Would it be any good using polycell smooth over to get a flat finish. Has anybody used this before or is it best to get it skimmed.
Scrape old nibs off with a 150mm angle head scraper from B&Q for about a fiver.
Even if it is skimmed it will still need doing.
