Error Code
5 Aug 2006
Hi All, checked the manual and the t'net, but cant get an answer.
What does the error code of CO stand for on a Vokera Boiler???
I think its either Co2 :shock: or some sort of combustion issue,but these are just a guess.
If it's the Linea you are talking about, it is not an error code.
It is telling you that it is set to the engineer set up max output mode :wink:
ive still never seen this mythical CO thing in all the hundreds of lineas ive seen. isnt the solution to unscrew the wee cap on the front and push the button behind it? cant remember.
next to the ch selector there is a screw type plug, unscrew it use a screwdriver and press the black toggle to disengage combustion mode.
Thanks guys, i stuck it on reset for 10seconds, and all is well.
Just wonder what caused it to go into this mode???
Ho-hum. Will be getting it serviced next week.
