Hi
I have a Vaillant Exclusive 832, which feeds 7 radiators in my bungalow. I have an issue with radiators making like a whistling noise when the heating comes on in that room (I use EvoHome so only one or two rads are normally on at one time).
When the boiler was installed, it was not configured at all, they put it in and scarpered (about 5 years ago now, before I fitted EvoHome too). About two years ago I looked into it as our gas was much much higher than before and noticed that the output had been left on max, so I reduced this down to the lowest setting which I think was 8KW.
Now I am thinking that due to the whistling noise, should they have configured the pump speed or auto bypass? It does sound like the pump is too high but I am no expert in boilers.
There is one rad that doesn't have a TRV fitted, that is a large towel rail in the bathroom.
I have looked at the manual which states "If noises are produced in the radiators or radiator valves" then "Regulate the pressure using the adjusting screw" by "Positioning the adjusting screw" to "5 further turns to the left from the mid-position". Does that sound like what I need to do?
Any help would be greatly appreciated.
