I have a mystery to solve. I live in a first floor flat in a 3 story building built in 1994. On the outside wall is a elliptical dark patch, almost 1m across, on the brickwork, with my overflow pipe roughly in the centre left to right and near the top. The patch overlaps my flat and the one below. The patch appears dry to the touch but looks like it is damp. No water has been seen coming from the overflow pipe (which projects about 15cm) but there may have been some. No water has come from it recently (collector has been attached).
I (and a site services engineer) thought some water had come through the overflow pipe, perhaps in strong winds, and dampened the brickwork beneath it. The only possible cause appeared to be the header tank which has an overflow pipe entering the water vertically (anyone know why) - the water level was surprisingly near the level where the pipe turns horizontal, so I adjusted the ballcock to lower the level of water a little. Not a drop of water has come out of the overflow since.
And that would be the end of it, except the patch has not reduced much, so I am concerned that there is more here than was suspected. Have you any comments, advice or theories?
