Extractor fan relay
As it is going to be a DIY build then using a safe ELV supply on bits in and around the shower area is going to reduce any hazards of electric shock to almost zero.
Put a flow switch in the water supply to the shower in the roof space, would be my suggestion.
Like I suggested over a week ago?
Buy a water flow switch to enable the fan when water is running.
Something like THIS maybe.
PS RCD protection essential!
If you're a more competent electrician than plumber then you could try it!
Note that it seems to require a 24 V DC power supply. IIRC, the ones that I linked to didn't; they were also more enclosed. You might also be able to find ones where the clamp can be opened, avoiding the need to thread the conductor through it - though you'll still need to separate the live and neutral conductors.
