fab softener tray wont empty??????
21 Sep 2005
hotpoint whirlpool is the model.could there be a possible blockage??anybody had this problem.is it summat simple??
Take out the drawer and wash it in hot water with a nylon washing-up brush. Usually it is clogged with congealed softener and soap powder.
Yours might have a two-part container that you can take apart, with two pipes that fit inside each other to make a syphon. Clean that out well. Observe it carefully so that you reassemble it right.
Give it a clean once a month or so.
Also look upwards for the water jets that squirt into the drawer, and scrub then free of blockages.
Come back if that doesn't fix it in case it is the electric valve or internal pipes.
are you sure?
hotpoint and whirlpool are 2 companies. hotpoint call theirs by a couple of letters then some numbers (the new ones anyway)
i.e wt965
so which is it, oh and you may also want to read the post appliances cures and manuals
thanks guys ,ill have a look.the model is a hotpoint aqarius 6kg wma50s to be specific
hiall.seems to be a blockage..ive given the tray and water jets aclean .touch wood,all a ok :P thanks
