Hello all
I have inherited a "non-working" Baxi 105e in my house that I moved into a couple of weeks ago.
From reading posts about these boilers if I describe the symptoms it probably points to a faulty PCB - but if anybody has any other ideas I'd be grateful (Kevplumb - you are probably the man!!)
I have no heating at the moment and would like to get it fixed before the snow sets in.
The symptoms of the boiler are - up until about a week ago it worked on and off for varying lengths of time but progressingly shorter. When firing the boiler up - the heating/water LEDs lit up together with the orange burner LED. Then (after a while, could be 5 minutes, could be 2 hours) it would trip out and the LED above 50 degrees (the fan/flue LED starts flashing). I have checked the fan and it spins freely and when putting an electrical tester to the live terminal power gets to the fan for a split second and I hear a click (sounds like a relay).
The flue pipe is completely clear.
For the last week the boiler does not kick in at all - only the 50 degree LED starts flashing after about 30 seconds. I can still hear a click after resetting or selecting hot water or heating.
Assuming it is the PCB does anybody know where I can get a replacement (secondhand is OK) or my faulty one repaired.
Any comments / advice will be greatly appreciated.
Steve
Steve
