faulty shower mixer
30 Jul 2008
Bristol
Hi, can you help?
I have a bog standard plunger type shower mixer, it’s only six months old but I when I came to use it this morning it wouldn’t work properly. When you pull up the plunger only a trickle of water goes to the shower head, I’ve checked the pressure and that is fine. :cry:
Do I need a new mixer of can I repair it myself, if so how?
FIrst see if the hose is twisted - remove from mixer then turn mixer on.
Yes those mixers are mendable with a washer/O ring, but some of them are real crap.
thanks ChrisR, the hose is ok I checked that this morning.
When I pull up the plunger though it does feel easier than normal, one thing that has crossed my mine is that last night I did leave the shower running for some time on only hot water, could this have damaged anything?
we have a combi boiler btw.
No. Time to get your spanners out and take the valve apart!
no problem I'll do that tonight.
I'm in a hard water area (Bristol) so maybe that has caused the problem?
