Hi
I have fitted a thermostatic mixer shower (Bristan™ Oval Thermostatic) and seperate pump (Wickes) and no water hot or cold will come out of the shower work unless i lower the shower head, once running i can return it to its holder.
Also the pump will randomly start up for a second or two then stop this can be anytime including when no one is touching any other water supply (no flushing toilets, filling kettles etc)
The cold water is fed from a 22mm pipe from the tank in the loft and the hot from the hot water cylinder in the airing cuboard. The pump is in the airing cupboard next to the cylinder and the pipes then run up into the roof and across and down to the shower.
Why am i getting these problems?
