Fencing (Feather Edge)
31 May 2015
Leeds
Looking to put up a 6ft fence nothing too fancy really:
Gap width (top of wall): 3.6m - 3 posts (Uc4 post, 100mm x 100mm x 2400mm)
drop of 70cm to another level of ground (paving slab at an angel holding ground up) - 2m Gap to fill on the lower ground which requires a gate.
1x Uc4 Post, 100mm x 100mm x 3000mm (might be cut down a bit so I can slope the fence over the paving slab but I will wait to see how it looks - I will also have a spare 2400mm post should I decide to change the look).
another 1 or 2 2400mm posts on the lower ground to connect to a masonry wall and build a gate to.
However I'm not fully sure what measurements of rail to use, I do like the look of how this one was done:
http://www.mgohandyman.co.uk/wp-content/gallery/footer/fencing-www1.jpg
at a guess I'd say it's 25mm (width) x 50mm (height) does this sound about right? - I'd use 3 of these between each post has shown in the picture. I also like the rails nails onto the front of the post so I think I will go along with that.
So materials break down:
5x Uc4 post, 100mm x 100mm x 2400mm
7x 25mm x 50mm x 5.4 (treated) for the rails
7x 20KG postcrete bags
60 feather edge fencing boards (more then I need but some can go back after) - not sure if it get 100mm or 150mm width (from Wickes)
Galvanised Nails 50mm x 2.65mm for the feather edge fencing
What size screw what you recommend for screwing the rails to the post? 100mm?
Any problems with this?
Cheers
Timber Gravel board?
Look in toolstation for there green/organic timber deck screws, there cheap for a box of 200, used them on my fencing.
