Hello
I was wondering if you fine chaps and chapesses can help?
I bled my radiators today and subsequently had to refill my Ferroli 701 with more water. Except the flaming thing refused to fill. I took the refill loop off and all seemed fine. Anyway, after much faffing, I finally managed to get it to fill up.
I fired up the boiler and got rubbish water pressure all through the house and realised I hadn't turned the mains supply back on fully. Obviously, as you can tell, I am an expert at plumbing
So, after all that I fired up the boiler again, hot and cold running water running throughout. Beating my chest like an baboon in celebration of my alpha-male status, I then realised that the boiler would only send hot water when it was fired for central heating. So when the boiler is lying dormant and I request hot water (even when it is set to hot water on demand)... nothing. All the boiler sends is the hot water it has produced, but once that has run out, it sends cold water. The only way I can get constant hot water is waiting for the boiler to start, then turn the hot tap
Why is this and is there anything I have done above, which would cause such a problem?
The floor is, as they say, yours.
