ferroli boiler modena 80e
24 Aug 2007
Sussex
could any one help i cannot set the central heating i have the ferroli mondena 80e i followed the instructions i also moved the setting from summer to winter set the slider to p and selecte the times but what about the right slider (f) what is the setting for that ?have been trying for 5 days now the boiler has just been checked so there can not be anything wrong with it the pressure is at 1 .i am not very familar with d.i.y
i do have an electric fire if i feel cold now the light bulb by the boiler has gone will have to wait until the morning :cry:
are you referring to the digital timer built in your boiler?
In which case set the left slider to 'I' and the right slider to 'auto'. The boiler is now in constant CH mode.
Is the room stat up?
many thankyous for your reply sitting in the cold i was referring the left slider i have set that to 1 now and programmed the central :oops: heating tthn put the slider back to auto now wondering if anything will happen timed to turn on in the morning have been trying for 4 days now :lol:
If its set to 'I' then it should be on constant and overrides the timer.
Is the room stat up??
Its a thermostat usually in lounge or hallway downstairs and controls your boiler and rads when the heating is ON.
You may NOT have one.
i have noticed a green light was flashing although not now for the central heating have not noticed it come on yrt though does that mean it is in stand by or something
central heating seems to be in stand by still not working :( any idears what i should do i have jst had my yearly check and the engineer must of changed my settings and turned the central heating off and set the boiler for summer .i have set it to winter setting .and when i programmed i put the slider to p then moved it back to auto.there is no heating yet
what is happenin when i turn the hot water on the central heating green light starts flashing.
