- Joined
- 16 Jan 2006
- Messages
- 25
- Reaction score
- 0
- Country
I have a Ferroli F30 combi, the CH seems ok as the radiators get hot, but the DHW only runs lukewarm.
I have checked that the light for DHW comes on, so the flow sensor seems to be working, and the temp sensor measures 8.5k when mildly warm, which seems about right, the manual mentions 10K at 25C.
The CH sensor measures the same.
The boiler fires up, but I cant tell if it is modulating, the flame base bright blue bits are about 5 mm high and don't seem to vary.
I'm an electronics/ computer guy, so I'm not touching the gas. I suspect it may need the gas inlet and max/min pressures tested?
Any suggestions gratefully received, and can anyone sugest a heating engineer in the Glasgow area?
