Ferroli moderna 102
5 Apr 2010
West Midlands
Have a Ferroli Moderna 102 installed. For whatever reason, the boiler has started to work erratically - fine for varying periods of time. It will perform normally for a couple of days and then go "bonkers", being on for between 1 and 8 hours then switching off. Attempts to restart via the "reset button" fires the boiler up for about 5 seconds only (repeated attempts produce the same result) and the "closed down " state can last several hours.
Any suggestions?
thermistors/pump/board/fan/venturi,could be any of the above from the description,personally i would change both thermistors first.
