ferroli optima 701 boiler problem
4 Jul 2009
Gwent
can anyone help,when i turn the hot tap on the water goes from hot to cold but lately now i notice when i turn the hot on the boiler doesn't start up so i get cold water,me central heating works fine and the boiler starts when i turn the heating on.can you help cause i've had loads of answers to my complaint but no direct answer to what the problem is with my boiler.many thanx Brian
Try to stick to one post, as the forum rules require; if you want someone to solve your problems within the hour, hire an emergency repair engineer.
you asked in your other post if there is a way to check
your flow "meter". its a flow switch, NO NC
if you have a multimeter you can check to see if its working
