hi
i am having problem with the optima 901 if i turn the power off then back on switch to heating continuous the boiler will fire up then after 30 seconds shuts down then nothing also does the same if i power off power on and turn on hot water tap runs for 30 seconds then shuts down
it is also leaking water from auto air vent and the isolation screws for the ch flow and return pipes at the boiler
any ideas would be greatly appreciated
digger
digger
