Hello,i have come across a sigma with s/live to boiler bringing boiler on without pump L having an output from board.If you switch off boiler thermostat,pump kicks in and pump will then continue to run when you turn stat back on.Any ideas, board? Also boiler stat cuts out after about an hour and will not kick in unless you turn off/on at power supply
